Error: Particle that does not exist in the actor - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: Error: Particle that does not exist in the actor (/thread-4195.html) |
Error: Particle that does not exist in the actor - Sky d - 01-05-2024 Hi. I am getting an error saying that my particle attachment is not recognized. Any advice appreciated please? Quote:The particle group 'Receiver' references a particle that does not exist in the actor 'Obi Rope'. Thanks for your time. Here's a screenshot. In the image, I had clearly renamed my control points. So I'm not sure how to fix. At first, it was working fine, but then I switched to Dynamic because I wanted to have the pin constraint function active. That's when the error started to appear.
RE: Error: Particle that does not exist in the actor - josemendez - 01-05-2024 (01-05-2024, 10:30 AM)Sky d Wrote: Hi. This means you've added or removed control points, and or/changed the rope in a way that the particle group your attachment was referencing no longer exists, or refers to a particle that no longer exists. Just re-select the appropriate particle group in your ObiParticleAttachment's "particle group" dropdown. This should get rid of the problem. kind regards, |
