Bug / Crash Deleting instances of prefabs cause a bug in play mode - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: Bug / Crash Deleting instances of prefabs cause a bug in play mode (/thread-2734.html) |
Deleting instances of prefabs cause a bug in play mode - ThisIsFine - 03-02-2021 Hello, I've encountered a bug in my project, and was able to encounter it again on a new clean projet. I'm using Unity 2019 LTS and Obi Rope 5.6.2 1. I've a prefab, containing two objects dynamically linked by a rope. The solver is inside the prefab (with ObiFixedUpdater) 2. I put 3 instances of this prefab in a simple scene 3. Then, if I delete A, then B, then C, everything is fine... BUT ! If I delete C first, there is a big bug, and ropes from A go crazy and jump (or the spheres/cubes fly away) ! The attachment is almost broken (there is a big gap between the rope and the sphere) Could you help me/resolve this bug ? I can send a zip package is necessary, Thanks, RE: Deleting instances of prefabs cause a bug in play mode - josemendez - 03-02-2021 (03-02-2021, 12:18 PM)ThisIsFine Wrote: Hello, Hi there, If you could send a .zip of the project to support(at)virtualmethodstudio.com I will take a look at it. I don't quite understand your description. kind regards, RE: Deleting instances of prefabs cause a bug in play mode - ThisIsFine - 03-02-2021 Ok no problem, I've sent you my project. Thank you RE: Deleting instances of prefabs cause a bug in play mode - josemendez - 04-02-2021 (03-02-2021, 12:58 PM)ThisIsFine Wrote: Ok no problem, I've sent you my project. Hi there, Haven't received anything yet, just letting you know. cheers! RE: Deleting instances of prefabs cause a bug in play mode - ThisIsFine - 04-02-2021 (04-02-2021, 09:10 AM)josemendez Wrote: Hi there, Weird ! I've send it again, but this time using WeTransfer. RE: Deleting instances of prefabs cause a bug in play mode - josemendez - 04-02-2021 Got it! Will get back to you asap. RE: Deleting instances of prefabs cause a bug in play mode - josemendez - 04-02-2021 This is a known bug in dynamic attachments, introduced in 5.6.1 and fixed in 6.0 (yet unreleased). A quick fix is to open up ObiParticleAttachment.cs, and just remove/comment out line 456: Code: //if (torn) // <---comment this outOne thing I though I should point out about your current setup: you're using an independent updater/solver for each prefab instance. This is a big no-no. This means each solver and its rope will be updated sequentially, negating most multithreading benefits. Usually you're supposed to have a single Updater component in your scene that updates all solvers in parallel. See: http://obi.virtualmethodstudio.com/tutorials/bigpicture.html http://obi.virtualmethodstudio.com/tutorials/updaters.html To make things worse, all updaters use 3 substeps and have "substep unity physics" enabled. This will force rigidbody physics in your scene to be updated 3 times per updater, for a total of 9 full physics updates per frame. For very simple scenes it might be ok, but as soon as you add a few more ropes it will absolutely obliterate performance. let me know if I can be of further help. cheers! RE: Deleting instances of prefabs cause a bug in play mode - ThisIsFine - 04-02-2021 (04-02-2021, 10:45 AM)josemendez Wrote: This is a known bug in dynamic attachments, introduced in 5.6.1 and fixed in 6.0 (yet unreleased). A quick fix is to open up ObiParticleAttachment.cs, and just remove/comment out line 456: It's working now ! Thank you a lot for your efficiency Yes, for my original project (not the simple that I made to send for the bug report), I've one Updater, and dynamically add/remove solvers to it. The number of substeps is relative to the number of solvers. Have a good day ! RE: Deleting instances of prefabs cause a bug in play mode - josemendez - 04-02-2021 You're welcome! Have a good day too
