Help air drag? - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Cloth (https://obi.virtualmethodstudio.com/forum/forum-2.html) +--- Thread: Help air drag? (/thread-2654.html) |
air drag? - zagoalie - 21-12-2020 I'm noticing something odd, no matter what drag value I set the cloth too, continual motion does not result in the hanging part of the fabric staying behind the moving object. https://i.gyazo.com/a8cae921d9e01746173a5f616f1d35b6.mp4 notice in this video hos the cloth at the beginning trails behind the hand, but then it starts catching up to the hand and even moves in front of it before the hand has even started slowing down. I have both a linear inertia scale and world angular interia scale to 1 RE: air drag? - josemendez - 21-12-2020 (21-12-2020, 02:06 PM)zagoalie Wrote: I'm noticing something odd, no matter what drag value I set the cloth too, continual motion does not result in the hanging part of the fabric staying behind the moving object. I assume you are moving the solver around, not the cloth itself. if you move the solver, it does not matter how high you set aerodynamic drag or velocity damping as both the cloth and the "air" around it will move together with the solver. Drag is not an inertial force. |
