Help Place multiple solver objects on the stage - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Cloth (https://obi.virtualmethodstudio.com/forum/forum-2.html) +--- Thread: Help Place multiple solver objects on the stage (/thread-1313.html) |
Place multiple solver objects on the stage - QoQoo1321 - 12-08-2019 Hi. Unity crashes if there are more than 2 3D models with solvers on stage Since the 3D model needs to be scaled in real time, the solver object had to run under the 3D model. However, instantiating multiple 3D models on the stage causes a unity crash, which is a problem. Is there any way to deal with such cases? RE: Place multiple solver objects on the stage - josemendez - 12-08-2019 (12-08-2019, 07:20 AM)QoQoo1321 Wrote: Hi. It should not, most sample scenes contain more than multiple solvers. Can you post the crash log? RE: Place multiple solver objects on the stage - QoQoo1321 - 12-08-2019 (12-08-2019, 10:04 AM)josemendez Wrote: It should not, most sample scenes contain more than multiple solvers. Can you post the crash log? Thank you for your reply. Could you confirm the log? ------error.log libOni.dll caused an Access Violation (0xc0000005) in module libOni.dll at 0033:99770805. Error occurred at 2019-08-11_003208. C:\Program Files\Unity\Hub\Editor\2018.3.14f1\Editor\Unity.exe, run by Administrator. 89% physical memory in use. 3999 MB physical memory [440 MB free]. 2026 MB process peak paging file [1944 MB used]. 1666 MB process peak working set [1632 MB used]. System Commit Total/Limit/Peak: 5056MB/7081MB/5131MB System Physical Total/Available: 3999MB/440MB System Process Count: 102 System Thread Count: 1904 System Handle Count: 48385 Disk space data for 'C:\Users\ADMINI~1\AppData\Local\Temp\Unity\Editor\Crashes\Crash_2019-08-10_153205093\': 3213516800 bytes free of 60677943296 total. Read from location 00000001D4BCDD60 caused an access violation. Context: RDI: 0x0000000000000b46 RSI: 0x0000000055835b50 RAX: 0x0000000000000b46 RBX: 0x000000006325fd90 RCX: 0x000000001442f540 RDX: 0x0000000000000001 RIP: 0x00007ff899770805 RBP: 0x000000006325f7f0 SegCs: 0x0000000000000033 EFlags: 0x0000000000010206 RSP: 0x000000006325f630 SegSs: 0x000000000000002b R8: 0x0000000055835b50 R9: 0x000000006325f820 R10: 0x000000006325fd90 R11: 0x000000007eabc020 R12: 0x000000007eaf7020 R13: 0x000000007e850020 R14: 0x000000001442f540 R15: 0x000000003329f1d4 ---------------- RE: Place multiple solver objects on the stage - QoQoo1321 - 15-08-2019 I tried to create a simple test scene that can reproduce crash. I want you to open the obitest scene and check the operation And please tell me why the crash. https://drive.google.com/open?id=1qtoCkY4MzaZK8BVtRFew8C61O7Y3cIxI RE: Place multiple solver objects on the stage - QoQoo1321 - 19-08-2019 (15-08-2019, 06:03 AM)QoQoo1321 Wrote: I tried to create a simple test scene that can reproduce crash. I would be grateful if you could let us have your answer concerning this matter. |
