Animating rod rest position - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Rope (https://obi.virtualmethodstudio.com/forum/forum-4.html) +--- Thread: Animating rod rest position (/thread-2905.html) |
RE: Animating rod rest position - Hakazaba - 11-06-2021 Sorry, new problem. The event rod.Onblueprintloaded is never being triggered RE: Animating rod rest position - josemendez - 11-06-2021 (11-06-2021, 04:18 PM)Hakazaba Wrote: Sorry, new problem. The event rod.Onblueprintloaded is never being triggered It is for me, tested using this script: Code: using UnityEngine;Make sure you subscribe to it in Awake(). Blueprints are initially loaded in OnEnable(): if you subscribe to the event later, the blueprint will be already loaded (and hence, the event will not be triggered until the blueprint is re-loaded). RE: Animating rod rest position - Hakazaba - 11-06-2021 Code: void SetStartPos(ObiActor actor, ObiActorBlueprint blueprint){Eventfired never shows up in my console... It turns out this is because this is a different object, and on enable is before the awake of this object Also im getting a lot of crashes in my scene the heavier it gets with obi actors RE: Animating rod rest position - josemendez - 14-06-2021 (11-06-2021, 06:54 PM)Hakazaba Wrote: [...] The call order of event functions in different MonoBehaviours is undefined in Unity, unless you specify otherwise: https://docs.unity3d.com/Manual/class-MonoManager.html (11-06-2021, 06:54 PM)Hakazaba Wrote: Also im getting a lot of crashes in my scene the heavier it gets with obi actors I've worked with scenes with hundreds of actors in the past, didn't have any issues. Can you share a crash log? RE: Animating rod rest position - Hakazaba - 16-06-2021 Aparently the order of operations is a little bit more complicated according to this thread, in regards to OnEnable: https://forum.unity.com/threads/onenable-before-awake.361429/ Ill send logs via email RE: Animating rod rest position - josemendez - 16-06-2021 (16-06-2021, 03:33 PM)Hakazaba Wrote: Aparently the order of operations is a little bit more complicated according to this thread, in regards to OnEnable: [url=https://forum.unity.com/threads/onenable-before-awake.361429/]https://forum.unity.com/threads/onenable-before-awake.361429/ That thread describes the usual, documented behavior: - For each object, Awake() is always called before the same object's OnEnable(). - For different objects, there's no guaranteed relative ordering of their events unless you specify otherwise in the Script Execution Order window. That means if you have 2 objects with no hand-specified execution order, you can get several call orders: #1) object1.Awake() #2) object1.OnEnable() #3) object2.Awake() #4) object2.OnEnable() #1) object1.Awake() #3) object2.Awake() #2) object1.OnEnable() #4) object2.OnEnable() #1) object2.Awake() #2) object2.OnEnable() #3) object1.Awake() #4) object1.OnEnable() ...etc. What you will never get is an object's OnEnable called before its Awake() function. So, this cannot ever happen: #1) object2.OnEnable() #2) object2.Awake() See: https://docs.unity3d.com/Manual/ExecutionOrder.html Specifically, the "Update Order" section. RE: Animating rod rest position - Hakazaba - 16-06-2021 Yes, the problem before was that i had two separate objects... However, i copied your script exactly, placed it on the same object as the rod. And it worked, last night. Today it does not. RE: Animating rod rest position - josemendez - 17-06-2021 (16-06-2021, 11:43 PM)Hakazaba Wrote: Yes, the problem before was that i had two separate objects... The same applies to different scripts on the same object. By default, call order is undefined for different scripts. Quoting the documentation I linked you to yesterday: https://docs.unity3d.com/Manual/ExecutionOrder.html Quote:You cannot specify the order in which an event function is called for different instances of the same MonoBehaviour subclass. For example, the Update function of one MonoBehaviour might be called before or after the Update function for the same MonoBehaviour on another GameObject — including its own parent or child GameObjects. Simply use script execution order to specify that your script should run before ObiActor. A cleaner solution is to control actor loading yourself (which I believe you currently do, if memory serves me well). Simply subscribe to OnBlueprintLoaded before parenting the actor to a solver. RE: Animating rod rest position - Hakazaba - 17-06-2021 Oh my! I actually didnt know about the script executionorder panel window at all! I dont think i control actor loading either. Thank you for drawing my attention to this. RE: Animating rod rest position - Hakazaba - 19-06-2021 I'm sorry this has gone on so long, i have a new issue. If i edit the position and orientation of the particles on that event, The particles positions become {NAN,NAN,NAN} in the next update statement when i try to retrieve them with rod.GetParticlePosition(). I wonder if perhapse i am causing extreme accellerations by changing them, do i need to set the particles inertia to 0 somehow afterward? Or is the particle position value in local space related to the prior particle? At the moment i am supplying world coordenates. |
