Help Counting Fluid & Android Export - Printable Version
+--- Thread: Help Counting Fluid & Android Export (/thread-750.html)
Pages: 1 2
RE: Counting Fluid & Android Export - josemendez - 16-11-2018
(16-11-2018, 12:57 PM)Tuna.Y Wrote: Thank you Jose.
I have already tried to change Simple Fluid Renderer, and just tried again but nothing changed.
Is there anything that I should change except Obi Particle Renderer component's Shader in the Emitter object?
Take a look at the SimpleFluid sample scene, the renderer is set up at it should for mobile devices. Tested it with a Galaxy S4 and an iPhone 4S, works in both (not exactly cutting-edge devices anymore).
RE: Counting Fluid & Android Export - Tuna.Y - 16-11-2018
(16-11-2018, 01:07 PM)josemendez Wrote: Take a look at the SimpleFluid sample scene, the renderer is set up at it should for mobile devices. Tested it with a Galaxy S4 and an iPhone 4S, works in both (not exactly cutting-edge devices anymore).
Hi Jose,
I've checked the SimpleFluid sample scene. It doesn't show anything if I don't select "Render" from Obi Particle Renderer component. And When I check "Render", it shows me particles, which are formed by balls and they don't like fluid at all.
I have attached a screenshot.
EDIT: I was able to render these particles as fluid by changing Clipping Planes of Camera and selecting Simple2DFluid from Obi Particle Renderer. I only got 1 issue now,
I have the same settings with the Sample Simple Fluid scene, but my fluid is not alpha.
Thanks.
