Help Colorless liquid particles (URP). - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Fluid (https://obi.virtualmethodstudio.com/forum/forum-3.html) +--- Thread: Help Colorless liquid particles (URP). (/thread-3146.html) Pages:
1
2
RE: Colorless liquid particles (URP). - CreepGin - 25-10-2021 Someone can correct me if I'm wrong, but I think 1) You set in the corresponding ObiEmitterBlueprints' Capacity field 2) Easiest way is to just set the lifetime to be a large value 3) For a rough estimate, you can count the active particles through ObiEmitter.activeParticleCount. You can take a look at IObiParticleCollection and ParticleImpostorRendering for more info. RE: Colorless liquid particles (URP). - josemendez - 25-10-2021 (25-10-2021, 12:15 PM)Volchok Wrote: 1) Where to set the number of particles? CreepGin's answers above are correct, just for completeness: 1) Yes, you set your blueprint's capacity. Link to the manual: http://obi.virtualmethodstudio.com/manual/6.2/emittermaterials.html 2) When setting the emitter's lifetime to a *very large value*, note you can actually set it to infinite by typing the word "Infinity" into the numeric field, and pressing enter. This trick works with any numeric field in Unity, not just Obi's. 3) Count particles if you want a rough estimate, if you want the actual volume in cubic meters then multiply by the volume of a spherical particle: 4/3 * PI * (radius)^3. RE: Colorless liquid particles (URP). - Volchok - 29-10-2021 (25-10-2021, 04:04 PM)CreepGin Wrote: Someone can correct me if I'm wrong, but I think Thanks! I'll try to experiment. ![]() (25-10-2021, 04:49 PM)josemendez Wrote: CreepGin's answers above are correct, just for completeness: Thanks! I will try.
RE: Colorless liquid particles (URP). - DeprecatedHuman - 15-11-2021 I am having the same issue as the OP except that it's still not working for me. Here's the steps I tried in a new project: - create new URP project with Unity 2021.1.28f1 - import Obi Fluid, clicked "Yes to all" in the conversion dialog - imported Burst - got warnings in playmode: referenced script (Obi.BurstColliderWorld) missing (and one other) - manually imported com.unity.collections - I can run the sample but everything is pink - Edit => Render Pipeline => URP => Upgrade (all) materials - Scene runs, console does not log anything, but fluid is not rendered (btw turning on particles works as discussed above) How do I get Obi to display fluids in URP? RE: Colorless liquid particles (URP). - josemendez - 15-11-2021 (15-11-2021, 05:29 PM)DeprecatedHuman Wrote: I am having the same issue as the OP except that it's still not working for me. Here's the steps I tried in a new project: Did you set up URP fluid rendering at all? This is not mentioned in your steps, and will result in fluid not being rendered. You should follow the steps on the manual: http://obi.virtualmethodstudio.com/manual/6.2/fluidrendering.html Quote:-Add a ObiFluidRendererFeature to your pipeline's renderer feature list. Or this video: RE: Colorless liquid particles (URP). - DeprecatedHuman - 15-11-2021 (15-11-2021, 05:47 PM)josemendez Wrote: Did you set up URP fluid rendering at all? Oooooooh ... okay ... I didn't know about that. Thanks for the quick response! I'll look into that. TBH assets that I know which require setup remind the user about that with a popup or similar so there's no RTFM questions. Something to consider for a future update.
RE: Colorless liquid particles (URP). - josemendez - 15-11-2021 (15-11-2021, 06:07 PM)DeprecatedHuman Wrote: Oooooooh ... okay ... I didn't know about that. I'll look into that. The problem with this is that different use cases require different setups: setting up for the built-in pipeline, setting up for URP with fluid surface rendering, setting up for URP with flat fluid rendering, setting up granular rendering in either pipeline...are all done in slightly different ways. Imho if we added popups for all those you'd be thrown back into MS Office's Clippy experience ("it looks like you're writing a letter, can I help?") ![]() In cases where there's only one possible setup, popups are indeed a good idea. However if there's only one possible setup, it's even better if the engine sets it up automatically (which is what we try to do). |
