Broken scripts with update 6 -> 7
Had some issues with the update from Obi Rope 6 -> 7 in a project that used Obi Rope 6.  Luckily it's a scratch project.
1.  I tried upgrading on top of the old version but saw script errors so I removed all Obi files and installed fresh instead.  Of course, I have scripts and prefabs that depend on the older Obi files, so all of those break in the process of installation.  Even after the other issues were patched below, my existing code runs into Index Of Of Range errors on trying to load my existing rope blueprints, so now I have to see if it's a code issue or a blueprint schema change issue.  [Edit: I see the forum update guide says you have to regen blueprints.  I'm creating them from code, see below.]
2.  The demo scenes use a resource script called FPSDisplay.  It does not use a namespace, so it conflicted with another script I already had called FPSDisplay.  This caused compilation errors and breaks the script references in scenes that used either one (my existing scenes, as well as your demo scenes.)  Even after I added a namespace to my existing FPSDisplay, the script references were broken, so I had to add a namespace to your file and re-add it to the demo scene objects.  I thought Unity demanded all assets used namespaces to avoid this sort of conflict.  [Edit:  Similar breakage on SlowmoToggler which does not have a namespace (I have no such script but your demo scene had a broken link to it and Unity couldn't find it until I added one).]
3.  Many of your demo scenes use a built-in diffuse material for many objects.  Please define your own material for these objects, so that when I update all materials to URP these objects don't remain pink.
4.  There is no longer a type for ObiFixedUpdater.  I had a script that expected this type to force a regeneration of ropes (as I would deactivate and reactivate ropes in proximity to the player).  The CHANGELOG says all ObiUpdater types have been removed.  No guidance on what to do about scripts that referenced them.
Here is the code I'm trying to migrate.  It generates new blueprints on the fly during Start.
My prefab has four of these, and each one is spitting out Null Reference errors in your DrawGizmos in Edit mode.
Quote:NullReferenceException: Object reference not set to an instance of an object
Obi.ObiRopeCursorEditor.DrawGizmos (Obi.ObiRopeCursor cursor, UnityEditor.GizmoType gizmoType) (at Assets/Plugins/Obi/Editor/RopeAndRod/ObiRopeCursorEditor.cs:75)
Once I try running, I get Index Out Of Bounds errors in your ObiActor.LoadBlueprintParticles, when I provide the generated blueprint to ObiRope.  One error per rope, with different starting index numbers.
Quote:IndexOutOfRangeException: Writing to index 0 is out of range of '0' Capacity.
Obi.ObiNativeList`1[T].set_Item (System.Int32 index, T value) (at Assets/Plugins/Obi/Scripts/Common/DataStructures/NativeList/ObiNativeList.cs:98)
Obi.ObiActor.LoadBlueprintParticles (Obi.ObiActorBlueprint bp) (at Assets/Plugins/Obi/Scripts/Common/Actors/ObiActor.cs:995)
Obi.ObiActor.LoadBlueprint (Obi.ObiSolver solver) (at Assets/Plugins/Obi/Scripts/Common/Actors/ObiActor.cs:1161)
Obi.ObiRope.LoadBlueprint (Obi.ObiSolver solver) (at Assets/Plugins/Obi/Scripts/RopeAndRod/Actors/ObiRope.cs:187)
Screenplay.TightRope.Generate () (at Assets/__SHARED__/Scripts/For/Obi/TightRope.cs:109)
Screenplay.TightRope.Start () (at Assets/__SHARED__/Scripts/For/Obi/TightRope.cs:45)
// TightRope.cs
using System.Collections;
using UnityEngine.Assertions;
namespace Screenplay
    // Combines the logic of Obi's RopeBetweenTwoPoints and ObiRopeReel
    // to form a simulated rope between any two transforms, with managed slack.
    public class TightRope: MonoBehaviour, ICraneRope
        public ObiSolver solver;
        public ObiRopeCursor cursor;
        public ObiRope rope;
        public Transform start;
        public ObiParticleAttachment startAttachment;
        public Transform end;
        public ObiParticleAttachment endAttachment;
        public const float MINIMUM_SLACK = 0.0f;
        public const float MAXIMUM_SLACK = 1.0f;
        [Range(MINIMUM_SLACK, MAXIMUM_SLACK)]
        [Tooltip("How much additional length beyond distance from start to end")]
        public float slack = 0.1f;
        [Tooltip("How much change in length required to recalculate rope")]
        public float deltaLength = 0.05f;
        public float cursorMu = 0.5f;
        public float sourceMu = 0.95f;
        private float priorLength = float.NegativeInfinity;
        void Start()
            Generate();
            // the rope actor must be a child under a solver to start the simulation
            transform.SetParent(solver.transform);
        // ICraneRope
        public float GetLength()
            if (priorLength > 0f)
                return priorLength;
            return IdealLength();
        public float GetMaximumSlack() => MAXIMUM_SLACK;
        private float IdealLength()
            float taut = start.Distance(end);
            if (slack < MINIMUM_SLACK)
                slack = MINIMUM_SLACK;
            return taut + slack;
        public void Generate()
            if (start == null || end == null)
                return;
            // Adjust our transform:
            transform.position = start.position;
            transform.rotation = start.rotation;
            // Calculate control point positions and tangent vector:
            Vector3 startPositionLS = transform.InverseTransformPoint(start.position);
            Vector3 endPositionLS = transform.InverseTransformPoint(end.position);
            Vector3 tangentLS = (endPositionLS - startPositionLS).normalized;
            Vector3 normalLS = start.right;
            // Add rope actor / renderer / attachment components:
            rope = gameObject.GetComponent<ObiRope>();
            rope.ropeBlueprint = null;
            // Create the blueprint:
            ObiRopeBlueprint clone;
            clone = ScriptableObject.CreateInstance<ObiRopeBlueprint>();
            clone.resolution = 0.5f;
            // Build the rope path:
            int filter = ObiUtils.MakeFilter(ObiUtils.CollideWithEverything, 0);
            clone.path.AddControlPoint(
                startPositionLS, -tangentLS, tangentLS, normalLS,
                0.1f, 0.1f, 1, filter, Color.white, "start");
                endPositionLS, -tangentLS, tangentLS, normalLS,
                0.1f, 0.1f, 1, filter, Color.white, "end");
            clone.path.FlushEvents();
            // Generate particles/constraints:
            clone.GenerateImmediate();
            // Set the blueprint:
            rope.ropeBlueprint = clone;
            rope.LoadBlueprint(solver);
            cursor = gameObject.GetComponent<ObiRopeCursor>();
            // Attach both ends:
            startAttachment.target = start;
            startAttachment.particleGroup = clone.groups[0];
            endAttachment.target = end;
            endAttachment.particleGroup = clone.groups[1];
        // Update is called once per frame
        void Update()
            // get ideal rest length:
            float restLength = IdealLength();
            // if we haven't changed sufficiently, don't disturb it
            if (Mathf.Abs(restLength - priorLength) < deltaLength)
                return;
            cursor.cursorMu = cursorMu;
            cursor.sourceMu = sourceMu;
            cursor.UpdateCursor();
            // set the new rest length:
            cursor.ChangeLength(restLength);
            priorLength = restLength;
(21-12-2024, 10:35 AM)hariedo Wrote: Had some issues with the update from Obi Rope 6 -> 7 in a project that used Obi Rope 6.  Luckily it's a scratch project.
You can't install Obi 7 on top of a pre-existing Obi 6 installation, doing so will cause multiple compilation errors due to missing files/newly added ones. You must delete the /Obi folder and do a fresh install as explained in the upgrade guide.
Upgrading will require updating all your scripts and prefabs as warned in the manual. Several systems in Obi are now asynchronous (for instance, ObiRopeCursor) so scripting logic changes quite a bit. It's not a quick process. You should evaluate whether it's necessary for you to upgrade your project or stay on Obi 6, and maybe try 7 on upcoming projects.
(21-12-2024, 10:35 AM)hariedo Wrote: Even after the other issues were patched below, my existing code runs into Index Of Of Range errors on trying to load my existing rope blueprints, so now I have to see if it's a code issue or a blueprint schema change issue.  [Edit: I see the forum update guide says you have to regen blueprints.  I'm creating them from code, see below.]
There's been some changes to the scripting API as well, see the guide above.
(21-12-2024, 10:35 AM)hariedo Wrote: 2.  The demo scenes use a resource script called FPSDisplay.  It does not use a namespace, so it conflicted with another script I already had called FPSDisplay.  This caused compilation errors and breaks the script references in scenes that used either one (my existing scenes, as well as your demo scenes.)  Even after I added a namespace to my existing FPSDisplay, the script references were broken, so I had to add a namespace to your file and re-add it to the demo scene objects.  I thought Unity demanded all assets used namespaces to avoid this sort of conflict.
Thanks for reporting this! FPSDisplay does not indeed have its own namespace, could find a few other sample scripts that don't either. Will fix this in the next update.
(21-12-2024, 10:35 AM)hariedo Wrote: [Edit:  Similar breakage on SlowmoToggler which does not have a namespace (I have no such script but your demo scene had a broken link to it and Unity couldn't find it until I added one).]
This component is used in the "RopeAndJoints" scene, and it is added to the ObiSolver component. Just downloaded the asset fresh from the store  but could not find any missing references/broken links to SlowmoToggler. Unity's asset verification process does not report any either.
(21-12-2024, 10:35 AM)hariedo Wrote: 3.  Many of your demo scenes use a built-in diffuse material for many objects.  Please define your own material for these objects, so that when I update all materials to URP these objects don't remain pink.
Diffuse materials should also be picked up by Unity's auto-updater. Most of the objects in the scenes just use the Standard shader.
(21-12-2024, 10:35 AM)hariedo Wrote: 4.  There is no longer a type for ObiFixedUpdater.  I had a script that expected this type to force a regeneration of ropes (as I would deactivate and reactivate ropes in proximity to the player).  The CHANGELOG says all ObiUpdater types have been removed.  No guidance on what to do about scripts that referenced them.
See the upgrade guide for details on what to do:
Quote:In Obi 7, all ObiUpdater components have been removed. ObiSolvers now update themselves at the right time, automatically parallelizing work with other solvers in the scene. You should open up your scenes/prefabs and remove missing references to these components:
-ObiFixedUpdater
-ObiLateFixedUpdater
-ObiLateUpdater
The substeps parameter in the updaters has been moved to the ObiSolver component. It is important that you adjust the amount of substeps in your ObiSolver to match the value your ObiUpdater was using, as too many substeps can have a large impact on performance.
Quote:Here is the code I'm trying to migrate.  It generates new blueprints on the fly during Start.
Will try your script and get back to you asap. At a first glance, the cursor related code acts as if the change in length is immediate - which no longer is - so it will likely break.
-ObiFixedUpdater
-ObiLateUpdater
Yes, I saw that.  I had an editor script that would seek them out and ensure they were added to the solver, so that I could then seek out and .Generate all the dynamically created ropes at edit time.  If we can fix my TightRope script above, then I think we're okay.
Quote:You should evaluate whether it's necessary for you to upgrade your project or stay on Obi 6, and maybe try 7 on upcoming projects.
As mentioned at the top of the thread, this IS evaluating 7 on a scratch project.  That doesn't mean I want to just throw out useful mechanisms that I have set up in my library of scripts and prefabs.  I also am considering buying the last Obi asset, Softbody, and am not going to attempt to have Obi 6 Rope for compatibility and Obi 7 Softbody in the same project.
Quote:Diffuse materials should also be picked up by Unity's auto-updater. Most of the objects in the scenes just use the Standard shader.
There are two "auto-updaters" in Unity.  One goes through the whole project looking for stuff to mangle, and one just updates the selected materials in the selected folder.  There's no middle ground to just update scenes in the Obi sample folder.  If your demo scenes don't rely on BiRP materials, then updating materials in the Obi folder would be sufficient.  Just a suggestion on how to make your asset bulletproof.
Any luck in scripting a means to create a Rope Blueprint on the fly, that won't throw IORs?
(09-01-2025, 01:20 AM)hariedo Wrote: Any luck in scripting a means to create a Rope Blueprint on the fly, that won't throw IORs?
In your code you call LoadBlueprint() manually: just remove that line and the problem should be fixed.
Manually calling LoadBlueprint isn't needed in most cases -unless you're doing something out of the ordinary - as it's automatically called by ObiSolver at the right time as explained in the API docs. Calling it when the solver has not been initialized yet will result in index out of bounds, as the blueprint tries to access the (yet uninitialized) solver data arrays.
All you need for an actor to load a blueprint is to assign it, as the code examples in the manual show:
http://obi.virtualmethodstudio.com/manua...ctors.html
Doing:
rope.ropeBlueprint = yourBlueprint;
will automatically unload the previous blueprint (if any), clear internal state, and then load your new blueprint once the solver is ready. Note your script may also fail in Obi 6, as its success hinges on whether the solver's Start() is called before or after your TightRope's Start(). The order in which Unity calls events for different components is undefined by default.
Also keep in mind that ChangeLength() in Obi 7 takes a change in length as parameter, instead of an absolute value. So this:
should be:
cursor.ChangeLength(restLength - rope.restLength);
Definitely making progress, the startup is clean.
But still getting spammed by this shortly after first frame.
InvalidOperationException: The previously scheduled job BoundsReductionJob writes to the Unity.Collections.NativeArray`1[Obi.BurstAabb] BoundsReductionJob.bounds. You must call JobHandle.Complete() on the job BoundsReductionJob, before you can read from the Unity.Collections.NativeArray`1[Obi.BurstAabb] safely.
Unity.Collections.LowLevel.Unsafe.AtomicSafetyHandle.CheckReadAndThrowNoEarlyOut (Unity.Collections.LowLevel.Unsafe.AtomicSafetyHandle handle) (at <f5cef381160e49118a67ea125642e36a>:0)
Obi.BurstSolverImpl.GetBounds (UnityEngine.Vector3& min, UnityEngine.Vector3& max) (at Assets/Plugins/Obi/Scripts/Common/Backends/Burst/Solver/BurstSolverImpl.cs:367)
Obi.ObiSolver.UpdateVisibility () (at Assets/Plugins/Obi/Scripts/Common/Solver/ObiSolver.cs:2257)
Obi.ObiSolver.Render (System.Single unsimulatedTime) (at Assets/Plugins/Obi/Scripts/Common/Solver/ObiSolver.cs:1777)
Obi.ObiSolver.LateUpdate () (at Assets/Plugins/Obi/Scripts/Common/Solver/ObiSolver.cs:1165)
If there's more info about the prefab's setup that would help, I can list it.
(Yesterday, 12:34 AM)hariedo Wrote: Definitely making progress, the startup is clean.
I'm unable to reproduce this issue using your script. Would it be possible for you to share a scene/prefab that reproduces this, just in case the transform hierarchy setup or other factors other that the code are responsible for this? (if so, send it to support(at)virtualmethodstudio.com)
(Yesterday, 06:24 PM)josemendez Wrote: I'm unable to reproduce this issue using your script. Would it be possible for you to share a scene/prefab that reproduces this, just in case the transform hierarchy setup or other factors other that the code are responsible for this? (if so, send it to support(at)virtualmethodstudio.com)
While whittling down my test scene, I found that it occurs whenever all ropes are outside the camera's culling frustum.  It stops as soon as any rope's bounds return to the camera's frustum.
This doesn't happen in the Obi sample scene "Crane" so I am still digging into which part of my setup may be causing it.
Yup. When the Solver's "Simulate When Invisible" is OFF, and your camera is aimed away from all ropes, the spam begins. Your "Crane" sample keeps this option ON, so by default it does not cause this issue. If you turn it OFF and rotate the main camera's Y value, your sample scene will generate the same errors.
(11 hours ago)hariedo Wrote: While whittling down my test scene, I found that it occurs whenever all ropes are outside the camera's culling frustum.  It stops as soon as any rope's bounds return to the camera's frustum.
Could reproduce the issue, thanks for reporting it!
This is an issue with the Burst backend attempting to read solver bounds in a specific situation where they might not be ready yet. To fix it, open up ObiSolver.cs and in the first line of its UpdateVisibility() method (around line 2249 in the file) add this:
simulationHandle?.Complete();
Should look like this:
private void UpdateVisibility()
            simulationHandle?.Complete(); //NEW
            using (m_UpdateVisibilityPerfMarker.Auto())
                using (m_GetSolverBoundsPerfMarker.Auto())
                    // get bounds in solver space:
                    Vector3 min = Vector3.zero, max = Vector3.zero;
                    implementation.GetBounds(ref min, ref max);
                    m_Bounds.SetMinMax(min, max);
This should ensure bounds are available before reading and fix the problem. Let me know how it goes!
