This is the complete list of members for Obi.ObiPath, including all inherited members.
| AddControlPoint(Vector3 position, Vector3 inTangentVector, Vector3 outTangentVector, Vector3 normal, float mass, float rotationalMass, float thickness, int filter, Color color, string name) (defined in Obi.ObiPath) | Obi.ObiPath | |
| arcLenghtSamples (defined in Obi.ObiPath) | Obi.ObiPath | protected |
| ArcLengthSamples (defined in Obi.ObiPath) | Obi.ObiPath | |
| ArcLengthTable (defined in Obi.ObiPath) | Obi.ObiPath | |
| Clear() (defined in Obi.ObiPath) | Obi.ObiPath | |
| Closed (defined in Obi.ObiPath) | Obi.ObiPath | |
| colors (defined in Obi.ObiPath) | Obi.ObiPath | |
| ControlPointCount (defined in Obi.ObiPath) | Obi.ObiPath | |
| dirty (defined in Obi.ObiPath) | Obi.ObiPath | protected |
| filters (defined in Obi.ObiPath) | Obi.ObiPath | |
| FlushEvents() (defined in Obi.ObiPath) | Obi.ObiPath | |
| GetClosestControlPointIndex(float mu) (defined in Obi.ObiPath) | Obi.ObiPath | |
| GetMuAtLenght(float length) | Obi.ObiPath | |
| GetName(int index) (defined in Obi.ObiPath) | Obi.ObiPath | |
| GetSpanControlPointForMu(float mu, out float spanMu) (defined in Obi.ObiPath) | Obi.ObiPath | |
| GetSpanCount() (defined in Obi.ObiPath) | Obi.ObiPath | |
| InsertControlPoint(int index, Vector3 position, Vector3 inTangentVector, Vector3 outTangentVector, Vector3 normal, float mass, float rotationalMass, float thickness, int filter, Color color, string name) (defined in Obi.ObiPath) | Obi.ObiPath | |
| InsertControlPoint(float mu) (defined in Obi.ObiPath) | Obi.ObiPath | |
| Length (defined in Obi.ObiPath) | Obi.ObiPath | |
| m_ArcLengthTable (defined in Obi.ObiPath) | Obi.ObiPath | protected |
| m_Points (defined in Obi.ObiPath) | Obi.ObiPath | |
| m_TotalSplineLenght (defined in Obi.ObiPath) | Obi.ObiPath | protected |
| masses (defined in Obi.ObiPath) | Obi.ObiPath | |
| normals (defined in Obi.ObiPath) | Obi.ObiPath | |
| OnControlPointAdded (defined in Obi.ObiPath) | Obi.ObiPath | |
| OnControlPointRemoved (defined in Obi.ObiPath) | Obi.ObiPath | |
| OnControlPointRenamed (defined in Obi.ObiPath) | Obi.ObiPath | |
| OnPathChanged (defined in Obi.ObiPath) | Obi.ObiPath | |
| points (defined in Obi.ObiPath) | Obi.ObiPath | |
| RecalculateLenght(Matrix4x4 referenceFrame, float acc, int maxevals) | Obi.ObiPath | |
| RemoveControlPoint(int index) (defined in Obi.ObiPath) | Obi.ObiPath | |
| rotationalMasses (defined in Obi.ObiPath) | Obi.ObiPath | |
| SetName(int index, string name) (defined in Obi.ObiPath) | Obi.ObiPath | |
| thicknesses (defined in Obi.ObiPath) | Obi.ObiPath |
