This is the complete list of members for Obi.ObiNativeQueryShapeList, including all inherited members.
| ObiNativeQueryShapeList(int capacity=8, int alignment=16) (defined in Obi.ObiNativeQueryShapeList) | Obi.ObiNativeQueryShapeList | |
