This is the complete list of members for Obi.ObiNativeQueryResultList, including all inherited members.
| ObiNativeQueryResultList(int capacity=8, int alignment=16) (defined in Obi.ObiNativeQueryResultList) | Obi.ObiNativeQueryResultList | |
