How make slow disappearing puddle?
Can i make slow disappearing puddle, by decrease radius of each particle witch collide with the floor? I try to change the size of particle by Obi Particle Renderer, but it scale all rendered particles. And new flow of water affect old one. Or exists some method to split particles and change scale of each groups by Obi Particle Renderer.
(13-03-2019, 08:20 AM)Andrew Wrote: Can i make slow disappearing puddle, by decrease radius of each particle witch collide with the floor? I try to change the size of particle by Obi Particle Renderer, but it scale all rendered particles. And new flow of water affect old one. Or exists some method to split particles and change scale of each groups by Obi Particle Renderer.
You cannot change the size of fluid particles at runtime, because each one of them represents a fixed volume of fluid. Removing particles one by one is the only method of making fluid disappear.
(13-03-2019, 08:38 AM)josemendez Wrote: Hi,
Thanks! Can you help me with it? I know how delete particles on collision, but i'm not sure how to store all particle after collision and remove it while after some time.
   private HashSet<int> currentParticles = new HashSet<int>();
   void Solver_OnCollision(object sender, ObiSolver.ObiCollisionEventArgs e)
       if (e.contacts.Count > 0)
           for (int i = 0; i < e.contacts.Count; ++i)
               if (e.contacts.Data[i].distance < 0.001f)
                   Component collider;
                   if (ObiCollider.idToCollider.TryGetValue(e.contacts.Data[i].other, out collider))
                       if (collider == _targetCollider)
                           currentParticles.Add(e.contacts.Data[i].particle);
                           ObiSolver.ParticleInActor pa = _solver.particleToActor[e.contacts[i].particle];
                           ObiEmitter emitter = pa.actor as ObiEmitter;
                           if (emitter != null && emitter.fluidPhase != 4)
                               emitter.life[pa.indexInActor] = 0;
           _particles.ExceptWith(currentParticles);
           _counter += _particles.Count;
           _particles = currentParticles;
 Is this code need some improvement to accurate calculate all particles?
