Did ObiCloth support 3rd party mesh collider script?
https://assetstore.unity.com/packages/to...der-134833
This stuff can generate mesh collider in run-time.
So, did it compatible with obi cloth( obi collider )?
If yes, it's so wonderful to create accurate simulation.
(11-03-2019, 03:48 PM)akuei2 Wrote: https://assetstore.unity.com/packages/to...der-134833
No, Obi only supports built-in colliders. Support for third party collider implementations must be done on a per-case basis. It depends a lot on how the third-party collider implementation works.
Anyway if you were planning on using this for character clothing, the traditional approach to this (animation/simulation blending) is fully supported by Obi, and doesn't even need to perform collision detection in most cases. Using a mesh collider for character-cloth collision is extremely unrealiable (in addition to inefficient) due to tunneling, so it is generally a very bad idea unless you're using extremely small time steps.
See:
http://obi.virtualmethodstudio.com/tutor...thing.html
