Help  move each particle of cloth
Hello. I would like to move each particle of cloth. My image is that pushing cloth from inside of tube shaped cloth. I want it to transform its shape depending on power.
(18-02-2019, 03:22 PM)Richard Wrote: Hello. I would like to move each particle of cloth. My image is that pushing cloth from inside of tube shaped cloth. I want it to transform its shape depending on power.
You can get/set any of the particle properties (positions, velocities, radii, etc) using the arrays in the solver class. See the docs for details:
(19-02-2019, 09:10 AM)josemendez Wrote: Hi,
I cannot image how to do. What if I move some of particles to X axis and then Z axis?
(19-02-2019, 09:26 AM)Richard Wrote: I cannot image how to do. What if I move some of particles to X axis and then Z axis?
Particle positions use the standard Unity Vector4 datatype. So to set the X value and the Z value, you simply pass them to the constructor as you normally would.
solver.positions[index] = new Vector4(x,y,z,0);
Please refer to Unity's documentation for more info how to use the Vector4 class.
(19-02-2019, 11:48 AM)josemendez Wrote: Hi,
Hello.
How can I pick up particles on script? I want to choose particles like around arms and shoulders.
