Butterfly net
I need to create a realistic butterfly net for a VR project. Would it be possible to do so with Obi Cloth? Ie. to attach a piece of cloth to a circular handle, and use a transparent texture with the network pattern.  If I buy a license for obi cloth, would I find some documentation to easily create something like that?
Many thanks!
(04-12-2018, 01:53 PM)glueball Wrote: I need to create a realistic butterfly net for a VR project. Would it be possible to do so with Obi Cloth? Ie. to attach a piece of cloth to a circular handle, and use a transparent texture with the network pattern.  If I buy a license for obi cloth, would I find some documentation to easily create something like that?
Many thanks!
Yes, it should be a fairly easy thing to do with Obi. You can use any material you like for the net mesh, as it is just a regular mesh. Any cutout of alpha blending shader will do.
As per documentation, you can take a look at it before deciding to buy:
