Threads: 3
27-09-2018, 03:16 PM
(This post was last modified: 27-09-2018, 04:15 PM by Mitch@PG.)
Have tried importing via Asset Store, and via the Assets menu; result the same, as in image below.
Unity v 2018.2.9.f1 64 bit
This is a newly created project, apart from a cube with a material attached.
Build platform is PC / Mac / Linux standalone.
Please advise if any other details are necessary.
Have attached image as well, in case the inserted / linked image does provide enough detail.
Update
On our OS X machine, ObiFluid imports into a Unity 2018.3.0b3 project and runs just fine. So the issue seems to be with / on my development machine.
Threads: 3
27-09-2018, 04:17 PM
(This post was last modified: 27-09-2018, 05:01 PM by Mitch@PG.)
Update
DLL file/s appear to be in the correct place/s.
Update
So ... well, something. Unity can't find the DLL, but it can find both, when the DLL has been copied to another place ...
I could really do with a bit of assistance here.
27-09-2018, 05:03 PM
(This post was last modified: 27-09-2018, 05:04 PM by josemendez.)
(27-09-2018, 04:17 PM)Mitch@PG Wrote: Update
Update
Simply restart Unity.
Unity only loads native plugins (.dll, .bundle, .so, etc) upon starting, it cannot hot-(re)load them.
Threads: 3
(27-09-2018, 05:03 PM)josemendez Wrote: Simply restart Unity.
.... Ok.
That could really do with being in the Quick Start PDF!
Also, it worked fine on the Mac straight out of the box?
27-09-2018, 08:12 PM
(This post was last modified: 27-09-2018, 08:22 PM by josemendez.)
(27-09-2018, 05:17 PM)Mitch@PG Wrote: .... Ok.
Sure, we'll mention it in the quickstart, thanks for the suggestion!. Note however it is mentioned in the official Unity docs, and the editor itself presents a warning when you select any native library:
The message is a bit unclear tough, as it does not specifically mention that you need to restart not only when the library needs to be un/re/loaded, but also if it needs to be loaded the first time.
Edit: Under macOS, this does not seem to be necessary. Being a unix-based os, it can pick up changes in native binaries without the need to restart Unity.
cheers,
Threads: 3
(27-09-2018, 08:12 PM)josemendez Wrote: Hi,
Honestly, I've not ever seen that message, but then I've also never used an external DLL with Unity, sooo ...
Mainly, I'm embarrassed that I forgot the very first rule of IT troubleshooting: "Turn it off and on again"!
