28-08-2018, 10:52 PM
Is it possible to make the cloth taut in real time? For a camping simulation to set up a tent, I'd like to "pin" the cloth down in the corners and make it taut.
Help Is it possible to make the cloth taut in real time?
29-08-2018, 08:43 AM
(This post was last modified: 29-08-2018, 08:43 AM by josemendez.)
(28-08-2018, 10:52 PM)jb88886 Wrote: Is it possible to make the cloth taut in real time? For a camping simulation to set up a tent, I'd like to "pin" the cloth down in the corners and make it taut. You can scale down the distance constraints by setting the stretching scale to something < 1: http://obi.virtualmethodstudio.com/tutor...aints.html This will make it "shrink", which will tense it up if its edges have been pinned down. (29-08-2018, 08:43 AM)josemendez Wrote: You can scale down the distance constraints by setting the stretching scale to something < 1: Great, thank you! Another question, do you know how I can get the particle index from collision to change it to fixed from unfixed upon collision in the script? I read that you can set the particle position, but I didn't see if there was a method to get the index.
29-08-2018, 05:13 PM
(This post was last modified: 29-08-2018, 05:13 PM by josemendez.)
(29-08-2018, 04:04 PM)jb88886 Wrote: Great, thank you! just use Code: int index = contact.particle; http://obi.virtualmethodstudio.com/tutor...sions.html |
« Next Oldest | Next Newest »
