Help  Slowed Simulation Problems
Hello!
I've recently started using ObiCloth to enhance some of my characters' clothing and I'm in the process of integrating my own slo-mo logic into it (as I'm avoiding using Unity's own timescale).
Recently I've been running into a problem with the clothing deforming and "crinkling" during this slo-mo process. You can see this effect in this gif. You can also see the change that I've made to ObiSolver's LateUpdate (as I saw you recommended in a previous thread) posted below.
Any insight into this would be welcome (I'm also having problems with collisions and clipping but that's a separate issue that I'll bugfix later)!
private void LateUpdate(){
        if (Application.isPlaying && simulationOrder == SimulationOrder.LateUpdate){
               // smooth out timestep and accumulate it:
               if (SlowTimeManager.fTimeScaleGlobal != 0)
                   smoothDelta = Mathf.Lerp(Time.deltaTime / SlowTimeManager.fTimeScaleGlobal, smoothDelta, 0.95f);
               else
                   return;
             AccumulateSimulationTime(smoothDelta);
            SimulateStep(smoothDelta);
        if (!Application.isPlaying)
            return;
        EndFrame (simulationOrder == SimulationOrder.LateUpdate ? smoothDelta : Time.fixedDeltaTime);
        if (OnFrameEnd != null)
            OnFrameEnd(this,null);
(16-08-2018, 11:37 AM)Reiffer Wrote: Hello!
               else
                   return;
return;
We have been unable to reproduce this by altering the code as per your example. The resulting simulation is completely smooth. Are you positive that:
1.- The solver's simulation order is indeed set to LateUpdate?
2.- SlowTimeManager.fTimeScaleGlobal is always >= 1? (as values smaller than 1 would speed things up instead of slowing them down)
(16-08-2018, 02:50 PM)josemendez Wrote: Hi,
fTimeScaleGlobal was the problem, as you noticed. My maths teach would be ashamed of me.
Thanks so much for the assist!
