Help  Pin coinstraint help needed
Hello, i just recently purchased the obi rope from unity asset store. And right away i need help haha.
Anyway, the problem im facing is this: I put a obi rope between two objects like this:
https://gyazo.com/87a2204c676e04eed6a2f739df7a3b9c
and put an obi collider on both of the objects, then added pin coinstraints on both of the edges pins and started the game. and this is what happened.
https://gyazo.com/aa6939492b198dc04d7280451695954e
what am i doing wrong and how do i fix this?
(05-04-2018, 05:47 PM)Karlanton Wrote: Hello, i just recently purchased the obi rope from unity asset store. And right away i need help haha.
You can check what's happening by adding a ObiParticleRenderer component to the rope. It will draw its particles in the game view. See:
Most probably, your particles are colliding with the same collider they're pinned to, since you pinned them inside of the collider. Pin them outside, or disable collisions between these particles and the colliders by changing their phase:
On a side note, you're using a rope material meant for line rendering mode, but you're using procedural (thick) rendering mode. The normal map used by the material will look really weird.
cheers!
