Help  Oculus support
Dear sir,
May I know if the plugin will work with Oculus rift and an imported 3D model with interaction like pouring water?
Best,
Mike
(15-03-2018, 12:17 PM)mikechui Wrote: Dear sir,
Best,
Mike
Yes it will. However keep in mind that fluid rendering does not support single-pass stereo, you will have to set up two separate cameras one for each eye. See:
https://docs.unity3d.com/ScriptReference...etEye.html
(16-03-2018, 06:19 PM)josemendez Wrote: Hi there,
Dear Jose,
Thank you very much!
Best,
Mike
I got this to work with just one camera and multi-pass. I think I got it to work with the Oculus SDK but I am sure I got that to work with the VRTK Oculus and SteamVR SDK. At first I got some problems trying to do it, but then when I later tried to do the same thing and had experimented with two cameras and that then caused a lot of other problems, it suddenly worked with one camera for both SDKs.
