Help  Help with Obi Cloth Tearable
I just want to make the black line of this object to be teared only. I have tried to set the per-particle tear resistance but when the cut region was pretty bad. Are there any solution?
https://imgur.com/a/h7NLP
(12-03-2018, 09:33 AM)matchalover Wrote: I just want to make the black line of this object to be teared only. I have tried to set the per-particle tear resistance but when the cut region was pretty bad. Are there any solution?
Cloth can only be torn at vertices, but you cannot control which particular incident edges will be torn.
Doing so would require storing per-edge tear resistances in the mesh, it is something you could implement yourself if you really need it.
