I've a rope around 1 unit long, it's attached to a rod by the first and last particle with 2 static particle attachments.
On this rope there is cursor, depending on an object position (a VR controller) the cursor will either have the cursor at 0 or 1 (source always at .5) . Imagine you are pulling a rope either from the start or end.
So this rope can get bigger if you pull, everything works fine here.
Now when pulling I want to attach the closest particle from the controller to it. I'm getting the closest particle (avoiding the first and last) and create the attachment using this script:
And the behavior is weird, sometimes it works, sometimes points get stuck in the air like if they were attach to a world position. I feel like it's because I'm expanding the rope while dragging and sometimes the source particle can become the one attached?
Do you see any edge cases with this system?
Thanks a lot.
particleAttachment = rope.gameObject.AddComponent<ObiParticleAttachment>();
particleAttachment.enabled = false;
particleAttachment.target = m_Controller;
var group = ScriptableObject.CreateInstance<ObiParticleGroup>();
group.particleIndices.Add(attachedParticleIndex);
group.name = "Test";
particleAttachment.particleGroup = group;
particleAttachment.attachmentType = ObiParticleAttachment.AttachmentType.Static;
particleAttachment.enabled = true;
Thanks a lot.
