Help  Collision detection problom
Sorry to bother you. I want to create a system where when a cloth net collides with a rigid body, it indicates whether a collision has occurred. If a collision occurs, the scene should be reinitialized. However, with the current code, even though collisions appear to happen on screen, there is no indication of a collision being detected.
Here is the code attached to the  obi solver,
using System.Collections;
using UnityEngine;
using Obi;
public class CollisionEventHandlerchuang : MonoBehaviour
    ObiSolver solver;
    public int contactCount;
    private bool collisionOccurred = false;
    void Awake()
    void OnEnable()
        solver.OnParticleCollision += Solver_OnCollision;
    void OnDisable()
        solver.OnParticleCollision -= Solver_OnCollision;
    void Solver_OnCollision(object sender, Obi.ObiSolver.ObiCollisionEventArgs e)
        contactCount = 0;
        //foreach (var contact in e.contacts)
        //    if (contact.distance < 0.001f)
        //        collisionOccurred = true;
        //        contactCount++;
        // just iterate over all contacts in the current frame:
            Debug.Log("no bang chuang");
            if (contact.distance < 0.01)
                if (col != null)
                    Debug.Log("bang chuang");
                    contactCount++;
    public bool IsCollisionOccurred()
        return collisionOccurred;
    public int GetContactCount()
        return contactCount;
    void OnDrawGizmos()
        // Existing OnDrawGizmos code
Here is another code subscribed the collision event,  it is expected to return true when the collision happens. However, the false is always returned.
using Unity.MLAgents;
using UnityEngine;
using Obi;
public class SatelliteEnvController : MonoBehaviour
    public ObiSolverInitializer obiSolverInitializer;
    public CollisionEventHandlerchuang collisionHandlerchuang;
    public CollisionEventHandler collisionHandler;
    void Start()
        ResetScene();
        obiSolverInitializer.InitializeObiSolverPosition();
        collisionHandlerchuang = FindObjectOfType<CollisionEventHandlerchuang>();
        collisionHandler = FindObjectOfType<CollisionEventHandler>();
        if (collisionHandlerchuang == null)
            Debug.LogError("CollisionEventHandlerchuang not found in the scene.");
        if (collisionHandler == null)
            Debug.LogError("CollisionEventHandler not found in the scene.");
    void FixedUpdate()
        if (collisionHandlerchuang != null)
            bool collisionOccurred = collisionHandlerchuang.IsCollisionOccurred();
            int contactCount = collisionHandlerchuang.GetContactCount();
            Debug.Log("Collision occurred: " + collisionOccurred);
            Debug.Log("Number of contacts: " + contactCount);
You're subscribed to the wrong event. Should be OnCollision, not OnParticleCollision.
OnParticleCollision returns collisions between particles, while OnCollision returns "regular" collisions (against colliders).
See the manual for details:http://obi.virtualmethodstudio.com/manual/6.3/scriptingcollisions.html
Quote:Contacts can happen between a simplex and a collider, or between two simplices. To request the simplex-collider contact list from the solver, subscribe to its OnCollision event. To retrieve the simplex-simplex contact list, subscribe to its OnParticleCollision event.
(24-06-2024, 07:52 AM)josemendez Wrote: Hi,
Thank you, I got it!
