if loading obi fluid with corroutine, fluid does not render.
If I want to view a fluid like Honey but after a set amount of time - after the corroutine turn the game object to "Active" the fluid will not render out. I can see it if I select "Render Particles"
(28-02-2018, 07:42 PM)corbinyo Wrote: If I want to view a fluid like Honey but after a set amount of time - after the corroutine turn the game object to "Active" the fluid will not render out. I can see it if I select "Render Particles"
Hi Corbinyo,
What are you activating after the coroutine, the fluid renderer, or the emitter? Can you post your code?
(01-03-2018, 09:40 AM)josemendez Wrote: Hi Corbinyo,
Hi and thank you for the response! In fact I am activating the entire game object - does this effect the performance of the obi fluid?
