07-12-2023, 07:49 PM
I've gone through the little samples, and I see the ropes tearing, but when I make a new Zip Tie Obi Rope (.5 resolution, .1 size, 1 particle pool) and enable tearing (tested 10-450 in resistance and -1 - 5 on the other line) and I have it set as a small U shape (rotated 90deg so the bottom of the U is sticking out of the wall) and make another rope going through the U (.5 resolution) not tearable.
and when I pull the 2nd rope to strain the "zip tie"... it bends but then at its strain point, the 2nd rope passes through the zip tie instead of breaking the zip tie.
I've made a 3D cube shaped like a rod, ran it through the zip tie, and pulled out, and again, the zip tie didn't break, just let the rod pass through given enough strain/stretch.
What am I missing?
What am I missing?
