Help  Cloth collision actors
How can I obtain the actors that have collided with my cloth object?
Thanks!
Christopher
(15-07-2023, 07:30 AM)domopuff Wrote: Hello,
Thanks!
Christopher
You can get a list of all particle-particle contacts each frame by subscribing to solver.OnParticleCollision. Then it’s just a matter of retrieving the actor(s) involved in each contact. How to do this is explained in the manual: http://obi.virtualmethodstudio.com/manua...sions.html
Kind regards,
(15-07-2023, 11:03 AM)josemendez Wrote: Hi!
Kind regards,
Thanks for the reply! I managed to get the collisions detection working but performance did take a heavy hit. Any way we can try get the center points of a cloth instead?
(15-07-2023, 02:55 PM)domopuff Wrote: Thanks for the reply! I managed to get the collisions detection working but performance did take a heavy hit.
If you iterate trough all contacts in the main thread using a simple for loop and there's many contacts in your scene, performance will of course be less than good. Try doing this using jobs instead.
(15-07-2023, 02:55 PM)domopuff Wrote: Any way we can try get the center points of a cloth instead?
Sure, iterate trough all particles in the cloth and calculate their center of mass. There's a snippet in the manual that does just this, pasting it here for convenience:
using UnityEngine;
using Obi;
[RequireComponent(typeof(ObiActor))]
public class ActorCOM : MonoBehaviour {
    ObiActor actor;
    void Awake(){
        actor = GetComponent<ObiActor>();
    void OnDrawGizmos(){
        if (actor == null || !actor.isLoaded)
            return;
        Gizmos.color = Color.red;
        Vector4 com = Vector4.zero;
        float massAccumulator = 0;
        // Iterate over all particles in an actor:
        for (int i = 0; i < actor.solverIndices.Length; ++i){
            // retrieve the particle index in the solver:
            int solverIndex = actor.solverIndices[i];
            // look up the inverse mass of this particle:
            float invMass = actor.solver.invMasses[solverIndex];
            // accumulate it:
            if (invMass > 0)
                massAccumulator += 1.0f / invMass;
                com += actor.solver.positions[solverIndex] / invMass;
        com /= massAccumulator;
        Gizmos.DrawWireSphere(com,0.1f);
Again, doing this in the main thread using a for loop will be slow. Note you can directly use Obi solver arrays in a job, see the "Using Jobs to process particles" section at the end of the page linked above.
Thanks for your help. Managed to figure it out!
