Help  bodyA on Solver_OnCollision yielding arbitrary index
I am using Solver_OnCollision on CollisionEventHandler to discover colliding OBI bodies.
contact.bodyB provides the correct index = 2
However, contact.bodyA provides an arbitrary index of 352, which is well beyond the count of world.colliderHandles (there are 3).
Can you please advise? Code attached.
void Solver_OnCollision(object sender, Obi.ObiSolver.ObiCollisionEventArgs e)
// just iterate over all contacts in the current frame:
if (contact.distance < 0.001f)
ObiColliderBase HitCollider = world.colliderHandles[contact.bodyB].owner;
if (HitCollider != null && HitCollider.gameObject.tag != "Tether")
Debug.Log("Body count = " + world.colliderHandles.Count); // returns 3
Debug.Log("bodyA = " + contact.bodyA); // returns 352
Debug.Log("bodyB = " + contact.bodyB); // returns 2
if (world.colliderHandles[contact.bodyB].owner != null)
Debug.Log(HitCollider.gameObject.name);
(27-05-2023, 06:09 AM)michendo Wrote: I am using Solver_OnCollision on CollisionEventHandler to discover colliding OBI bodies.
Obi only deals with particles and Unity’s collider components. Particles and colliders are collectively referred to as “bodies”.
In the case of particle-collider contacts, bodyA is a simplex index, bodyB is a collider index.
In case of particle-particle contacts, both bodyA and bodyB are simplex indices.
In no case bodyA is a collider index. See the documentation for details:
By default (unless your cloth uses surface collisions) cloth simplices are made of one particle each. bodyA = 352 and bodyB = 2 means particle #352 in a cloth actor is colliding against collider #2.
Kind regards
