should I buy obi rope for my use
.This asset look to be perfect for my use, but I have few questions before buying it:
- I need the rop to break in a precise point and a precise tension.
The rope need to be at a precise distance between the strating point and the ending point before to break, and break at the middle or a choosen point.
Is it possible?
Thank you for your answer : )
(15-02-2023, 10:31 AM)edhoo Wrote: .This asset look to be perfect for my use, but I have few questions before buying it:
Is it possible?
By default, ropes break at the point of most tension. If you need it to break at a specific point, you must implement that yourself. This also can be done, by iterating trough rope elements and calling the Tear() method on them: http://obi.virtualmethodstudio.com/manua...ropes.html
There's an included sample scene that cuts ropes at user-specified points using swiping motion on the screen, similar to the "Cut the rope" mobile game.
