Help  How to count particles
Hi Everbody,
I making a simulation and I need to count particles in a area, for example I set a cube trigger and calculate how much particle inside in this cube.
Is this possible on Obi ,and if it does, how can I do that Sonrisa
(04-01-2023, 01:35 PM)mustafagulsoy Wrote: Hi Everbody,
Yes, just use collision callbacks to count the amount of particles inside a trigger collider. See:
Kind regards
(04-01-2023, 07:53 PM)josemendez Wrote: Hi!
Kind regards
Thank you for fast answer now I can count it but with collider not trigger, how can I create a trigger on obi fluids?
Best regards
(05-01-2023, 04:11 PM)mustafagulsoy Wrote: Thank you for fast answer now I can count it but with collider not trigger, how can I create a trigger on obi fluids?
Best regards
Triggers work the exact same way, just enable the “trigger” checkbox on your collider.
Kind regards,
Dedo arriba
(05-01-2023, 10:58 PM)josemendez Wrote: Triggers work the exact same way, just enable the “trigger” checkbox on your collider.
Kind regards,
Thank you so much These all solve my problem.
