Help  Check for collision of last particle in rope
Hi again,
I need a way to check if the last particle in the rope (i.e. end of the rope) has collided with an object.
I understand the last point in the rope can be obtained by elements but I'm not sure how to check for the actual particle.
If that last particle hits an object I need to assign that object as an ObiParticleAttachment.target.
Here's what I have so far.. any hints? Hoping to get this figured out before the holidays Guiño
void Solver_OnCollision(object sender, Obi.ObiSolver.ObiCollisionEventArgs e)
        //iterate over all contacts in the current frame:
            if (contact.distance < 0.01)
                if (col != null)
                    if (col.gameObject.layer == 15)
                        //if we are here we know particles are colliding with layer 15 objects.
                        //how can I know if it's the LAST PARTICLE in the rope (end of the rope) that has touched the debris?
            //I know this is supposed to return the position/point of the last particle..
                        Vector4 lastPoint = solver.positions[rope.elements[rope.elements.Count - 1].particle2];
(23-12-2022, 01:43 AM)docgonzzo Wrote: I understand the last point in the rope can be obtained by elements but I'm not sure how to check for the actual particle.
The last point in the rope is the last particle. Each element contains the indices of 2 particles in the solver, and each contact contains the index of 1 simplex and 1 collider. So all you've got to do is get the particle index from the simplex, and check whether it is the same as the element's:
                if (col != null)
                        if (rope.solver.simplices[contact.bodyA] == rope.elements[rope.elements.Count - 1].particle2)
                            //last particle in the rope hit a collider in layer 15!
See "retrieving the particle involved in a contact" in the scripting collisions section: http://obi.virtualmethodstudio.com/manua...sions.html
