Help  Obi Rope path tracking
I want to follow the path of the rope and move the characters, how can I do that?
Can we detect rope positions step by step?
[Image: JaZhKx.png]
Not entirely sure what you mean by "detect rope positions step by step", but I guess you mean getting particle positions in the rope? If so, you can do so by iterating trough the rope elements, getting the positions of particles using the particle API:
http://obi.virtualmethodstudio.com/manua...ropes.html
Thanks for the reply,
I want the character to move like the black line attached to the rope taking the positions I'm working on Obi's the sample scene right now.
[Image: Jabv6R.png]
Then it may be simpler to get  an orthonormal frame from the rope, which you can do by calling ObiPathSmoother's GetSectionAt(float mu) method. Given a normalized coordinate in the (0,1) range, it will return an orthonormal frame in the rope (containing position, normal, tangent, binormal).
var frame = rope.GetComponent<ObiPathSmoother>().GetSectionAt(0.5); // get frame at the middle of the rope.
(29-11-2022, 10:27 AM)josemendez Wrote: Then it may be simpler to get  an orthonormal frame from the rope, which you can do by calling ObiPathSmoother's GetSectionAt(float mu) method. Given a normalized coordinate in the (0,1) range, it will return an orthonormal frame in the rope (containing position, normal, tangent, binormal).
it was very good i edited it as i wanted thank you so much
