I've encountered an issue with pin constraints that even occurs in the demo samples provided with the asset:
When a rigidbody with a rope attached (via a pin constraint) is deleted, the rope will suddenly attach to another rigidbody in the scene.
I'm assumed originally that when one actor is deleted, any constraints between them would automatically get deleted as well. This appears to not be the case. Not to matter, it seems relatively simple to fix this: shove some code that destroys the ObiParticleAttachment script when the m_Target it points to gets destroyed.
I'm just wondering what you'd recommend to be the best way to handle this. Some ideas I had and the concerns involved with each:
Thanks!
- When the attachment gets created, add a simple script with OnDisable() handler that calls a delegate. Add a new method - OnTargetDisabled() - to the delegate, which is called when m_Target is disabled.
Concern: While simple, it seems unnecessary and incomplete. Given that an ObiCollider is needed to make a dynamic attachment, and the ObiCollider likely already handles its own destruction or deactivation, this could be a more elegant place to handle ALL relationships between the ObiCollider and other entities.
- Add code into the OnDestroy/OnDisable/OnEnable callbacks of ObiCollider (and/or ObiRigidbody) that ensure that upon its destruction or deactivation, relationships with other entities (be that via pin constraints, ObiParticleAttachment, or whatever other relationships I'm currently unaware of) are severed or suspended appropriately.
Concern: Modifying unfamiliar code is always a bit risky. Plus, I'm not sure where Obi keeps track of all the relevant relationships, whether they're enumerable, or if they're stored in a way where it'd be quick and painless to find them given a ObiCollider/ObiRigidbody. Besides, ObiParticleAttachment might not be informed that the constraint it generated was removed and misbehave, and extra handling would need to take place there anyway.
- I broke something and this is entirely my fault.
Concern: After reviewing the diffs between the latest version of unmodified Obi and the version I'm using with my changes included, there does not appear to be any changes that would interfere with how the demo scenes work.
Thanks!
![Gran sonrisa Gran sonrisa](https://obi.virtualmethodstudio.com/forum/images/smilies/biggrin.png)
