Bug / Crash  [Solved] Particle Capacity Not Updating
     First off, I'd like to say thanks for this awesome product, it is immaculate for fluid simulation! However, I've seemed to run into some sort of bug with the emitter blueprints. I cannot seem to update the capacity there. It was set at 1500, and changing it any amount above or below this value does not seem to affect the emitter at all. It still outputs exactly 1500 particles after making the change. I double checked all my scripts, and there doesn't seem to be any that would alter this value externally. What could be causing this?
Thanks in advance! Gran sonrisa
(25-04-2022, 07:13 PM)Freebird17 Wrote: Hello,
Hi! Sonrisa
Are you clicking the "Generate" button in your blueprint inspector? (or calling the Generate() coroutine, if doing this programmatically)?
(25-04-2022, 07:49 PM)josemendez Wrote: Hi! Sonrisa
It would appear that I somehow forgot to do that. Thank you! And sorry for the trouble– everything's working now.
Best,
   F17
