how to re-enable and disable, without skin going invisible on root object (original)
hello dev
for some reason on the BallPool example, when I try to disable the clone I make, it disables the original object mesh (the skinned mesh, found on base object) and doesnt re-render.
im trying to disable objects to save performance on runtime, but this is unusable in current state
whats correct way to disable obi softbody objects with this no-skinned-bones-weights skinned mesh setup, so it can disable children or clones, not lose mesh references, and also re-renable children or clones for performance?
(23-04-2022, 08:10 PM)usemahrope88 Wrote: hello dev
Thanks for reporting this! This is not the intended behavior. Will investigate and get back to you asap.
Hi again,
This was indeed a bug in the ObiSoftbodySkinner component, triggered by disabling it on an instanced object.
Attached you can find a fixed version of the component script. Just replace the one found at  /Obi/Scripts/Softbody/Rendering/ObiSoftbodySkinner.cs with this one.
Let me know how it goes,
.cs   ObiSoftbodySkinner.cs (Size: 17.55 KB / Downloads: 3)
