hinge joint components
Can i use obi softbody with unity hinge joint components ?
I want to create simple capsules interconnected like a chine using hinge joint. ( I am trying simulate sausages )
(22-03-2022, 05:09 PM)SABITH Wrote: Can i use obi softbody with unity hinge joint components ?
Hinges only make sense for rigidbodies. You could attach each softbody to a rigidbody, and then place a hinge between both rigidbodies.
Another option is to use ObiStitcher, which allows you to directly stitch two actors together.
