Shader errors when building for Android
I get some errors compiling for Android target
Using Unity 2020.3.30f
See screenshot of Unity Console
Note: I am not using any Obi shaders/materials, only Standard shader with color.
From the manual's setup guide:
Quote:If you're not using SRPs but the built-in pipeline, it's safe to delete the /Obi/Resources/ObiMaterials/URP folder. Otherwise Unity will raise an error at build time, stating that it cannot find the URP pipeline installed.
