Hello!
I created a new Unity project and imported Obi Cloth. The CharacterCloth sample and the Trampoline sample have the strange problem as the below pictures show. Other samples are all normal.
I tested two backends, they are the same.
I tested it in 4 Unity versions.
In Unity 2021.2.7f1c1, 2021.2.0b12.3482 and 2022.1.0b8.2747, the same issue occurs.
Luckily, in Unity 2020.3.29f1c1(LTS), this issue doesn't occur.
I tested on two PCs, the results are the same, maybe it's because the two PCs have the same CPU.
I can use Unity 2020 to continue my work, but it would be better to find out why the issue occurs.
I don't know if it is necessary to attach the project file, because it is just an empty project.
My system: Windows 10.0.19043 x64
CPU: Intel Core i5-4200H two cores four threadings
I'm sorry that my English is not good.
Thank you in advance!
