Curve Closed Option
Using the Obi Bezier Curve, create a Closed Curve.
The Rope generated by it keeps moving all the time.
It will not stop moving forever.
Why is this event occurring?
Can this be solved?
(I want to make a ring)
(08-07-2017, 03:33 PM)reblololo Wrote: Hi,
Can this be solved?
Hi reblololo,
Try setting your constraints to parallel mode. In sequential mode, vibration modes can be introduced for closed loops.
cheers!
Can this be solved?
Post is oldish, but you might want to try adding an obiMaterial to your ropes ObiRope component. Try adding one with high friction. There are premade obiMaterials in the sample project.
