Issues getting Softbody working
Hello, new user here.
I read through the setup instructions and installed the necessary packages from here:
http://obi.virtualmethodstudio.com/manua...html#burst
I'm getting this error popping up on my console:
Assets\Obi\Scripts\Common\Backends\Burst\BurstMath.cs(681,74): error CS8377: The type 'T' must be a non-nullable value type, along with all fields at any level of nesting, in order to use it as parameter 'T' in the generic type or method 'NativeList<T>'
I've tried starting a new project with Unity2020.311f1 and Unity 2021.1.5f1 and I'm getting the same error in both versions. I'm using Obi Softbody 6.3
I've been searching on the forum for a bit and I can't seem to get Obi up and running. Cheers in advance for any guidance or suggestions. Thanks!
(23-11-2021, 04:55 PM)kokutouchichi Wrote: Hello, new user here.
Sorry for the issue, I'm unable to reproduce this. What package versions you've installed? Just so that I can test the same setup you have.
Edit: the error says the type T in this declaration:
Quote:public static unsafe void RemoveRangeBurst<T>(this NativeList<T> list, int index, int count) where T : struct
must be non-nullable, but it is constrained to be a struct so it already is non nullable...  Huh
I did the same as the other poster suggested in this thread: http://obi.virtualmethodstudio.com/forum...-3197.html
That seemed to work! Changing:
where T : struct
to
where T : unmanaged
(24-11-2021, 04:07 AM)kokutouchichi Wrote: I did the same as the other poster suggested in this thread: http://obi.virtualmethodstudio.com/forum...-3197.html
where T : struct
to
where T : unmanaged
Yes! Sorry about it, it was a timing issue. As Obi 6.3 was released, Unity released a new version of the Collections package that requires making this change for it to work.
I'm uploading a patched version to the store as we speak. Sorry for the trouble!
