Help  How to set diffuse of liquid correctly?
What is the correct range of liquid diffuse? And is it relative to the diffusion data size?
When I set the diffuse of the 2 chemical liquids in LiquidMixing sample, I got these visual and log errors in the video.
(18-11-2021, 05:39 AM)Chua Polar Wrote: What is the correct range of liquid diffuse? And is it relative to the diffusion data size?
Diffusion is specified as % of diffusion per second. Not relative to the size/range of the diffusion data.
Can't see ay log errors attached to your post :/
Guiño
the video was too big.
It seems I can't post the image?
The video:
https://drive.google.com/file/d/1aC2vYqi...sp=sharing
(24-11-2021, 06:07 AM)Chua Polar Wrote: the video was too big.
The video:
Unfortunately it's not possible to upload videos to the forum directly, as that would skyrocket my hosting costs. Any video or large file uploaded, I have to pay to host it! hope you understand  Sonrojado Hosting on youtube, drive, etc and posting a link is the way to go.
The video you linked to is fun, but unrelated to Obi Guiño. Maybe you mixed up the links?
cheers,
(24-11-2021, 08:36 AM)josemendez Wrote: Hi!
cheers,
It was the wrong link LOL.
https://drive.google.com/file/d/1qw6OaQ8...sp=sharing
(24-11-2021, 09:58 AM)Chua Polar Wrote: It was the wrong link LOL.
The sample script being used (ObiPropertyColorizer) makes use of unity's animation curves, whose Evaluate() method only takes values between 0 and 1.
A value of 1 for diffusion is extremely large, so it will cause diffusion to overshoot (keep in mind that diffusion is time-dependent, and so subject to cfl stability conditions). The overshot diffused values will then go way beyond the 0-1 range, and since the sample script does not check for this----> error.
Just use a much smaller diffusion value, for instance 0.005. If you need very high diffusion values, you'll need to reduce your simulation's timestep size.
Checking for a valid 0-1 range in the sample script would make the error in the console go away, but still the fluid colors would vary wildly due to the high diffusion.
(24-11-2021, 10:48 AM)josemendez Wrote: The sample script being used (ObiPropertyColorizer) makes use of unity's animation curves, whose Evaluate() method only takes values between 0 and 1.
Got it!
