Rope that can be in water
I made a game with an ocean and a whole physical system associated with it.
Is it possible to add forces on given particles in a rope ? That way I could identify the particles under water and add resistance force to them.
(09-11-2021, 03:26 PM)lufydad Wrote: I made a game with an ocean and a whole physical system associated with it.
Yes, you can add forces to individual particles, and get/set any particle property. See:
You can also retrieve contact data and make spatial queries such as raycasts, box overlaps, etc:
http://obi.virtualmethodstudio.com/manua...eries.html
(09-11-2021, 03:56 PM)josemendez Wrote: Yes, you can add forces to individual particles, and get/set any particle property. See:
Thanks for your answer, indeed I didn't saw the property externalForces in ObiSolver.
Here is an example :
for (int i = 0; i < actor.solverIndices.Length; ++i)
     // retrieve the particle index in the solver:
     int solverIndex = actor.solverIndices[i];
     if(IsUnderWater(actor.solver.positions[solverIndex])
         actor.solver.externalForces[solverIndex] = MyForceForUnderWater;
     else
         actor.solver.externalForces[solverIndex] = MyForceForAboveWater;
(09-11-2021, 04:56 PM)lufydad Wrote: Thanks for your answer, indeed I didn't saw the property externalForces in ObiSolver.
The externalForces array is undocumented on purpose, since it is used internally by Obi's force zones. It's easy to break force zones by tinkering with it: your code overwrites the content of externalForces, so force zones will cease to work. You could fix this by adding the force instead of setting it to a fixed value.
Another option is to apply forces to the velocities array like this:
actor.solver.velocities[solverIndex] += MyForceForUnderWater * actor.solver.invMasses[solverIndex] * deltaTime;
Since F=ma, and acceleration is a change in velocity over time, your change in velocity is = F/m*dt.
(10-11-2021, 10:14 AM)josemendez Wrote: Hi!
However, generally it's a better idea to apply forces to the velocities array like this:
thank you for this clarification, it could indeed be useful Sonrisa
