Threads: 4
I've been going through the video tutorials and noticed a Path Editor window that shows up when editing the path. I'm running Unity 2021.2.0b10, and this window doesn't show up. I saw a thread from a few years ago that mentioned resetting the layout to the default, which I tried with no luck. Is this a known issue in Unity 2021 or is there something else I can try to get it showing up?
13-09-2021, 11:13 AM
(This post was last modified: 13-09-2021, 11:14 AM by josemendez.)
Beta and alpha versions of Unity are not officially supported. This being said, the path editor window does show up for me in 2021. Do you have multiple inspector windows open?
Threads: 4
Yes, it does appear to be a beta issue. I created an empty project on 2021.2.0b10 and the path editor won't show. I created another on 2021.1.20f1 and it does work. Maybe related to the new transform tools overlay in the scene view, which was added in 2021.2?
Threads: 0
15-11-2021, 02:59 PM
(This post was last modified: 15-11-2021, 03:48 PM by insideoutMcface.)
Hi! I have the same problem on 2021.2.2f1
its very wierd behaviour, gimos are there, show up with first click but with box sellection? And then you can move them even I cant see them
but 2021.2.0f1 is working - but without the menu in scene editor to add/remove points etc. I can prepare blueprints in older version as workaround, but hope it could be fixed
