Help  Can I Reach transform of each particle on rope.
I m trying to give water passing effect to the rope as the video in link below.  i think to give the effect; i can change the local scale of each particles at different duration.
the video link is here and i want to make between 0.07 - 0.10 seconds.
 https://streamable.com/d118np
how can i make it by using obi rope.
thank you in advance.
Note that particles don't have a "transform" as they're not gameObjects, they have separate position, orientation, and radius.
See the particle API documentation:
Using it you can change particle radius or any other per-particle property at runtime.
Thank you for your help. it worked.
