Hello!
I have object structure like this
ParentObject
---Obi Solver
------Obi Chain
---ChainBall
---ChainHandle
Then I move Parent object Obi Chain's physics works. I want physics only then I move ChainBall or ChainHandle. Is it any way to do it?
Thank you!
The simulation is always performed on the solver's space, so if you move the solver, any child actors will move together with it. Usual behavior you get with parent-child objects.
However you can attach ropes to any object (regardless of where it is in the hierarchy) and collisions also work with any objects. If I understood your question correctly, you can have:
ParentObject
---Obi Solver
------Obi Chain
ChainBall
ChainHandle
And just attach the ball and the handle to the chain.
29-06-2021, 01:04 PM
(This post was last modified: 29-06-2021, 01:18 PM by ikostyakov.)
I tried:
ParentObject
---Obi Solver
------Obi Chain
---ChainBall
---ChainHandle
and
ParentObject
---Obi Solver
------Obi Chain
---------ChainBall
---------ChainHandle
then I move ParentObject chain physics reacts on it. Can I make it react on ChainBall and ChainHandle movement only?
My problem - I have floating origin and sometimes need to shift ParentObject for 500 units and more. But then I move my object pore physics works like ParentObject have huge acceleration
Ok. I have same sample as you. I think my problem is my chain ball have IsKinematic flag. Can you test it?
That is it! Totally missed this property. Thanks a lot!
