Obi Particle Trigger
I just recently purchased obi rope and I have to say, it simulates beautifully. However I was wondering if an Obi Particle Trigger is possible. I want particles that are inside of the trigger to have different properties. For example I have a body of water and when a particle enters the body of water I want the drag to increase and the gravity to change.
I noticed the ObiSphericalForceZone, and this was a possible solution for the effect I wanted to achieve, however when the rope entered the sphere it was thrown out of the water, and placing many spheres under the water wasn't desirable.
For now I just created an obi collider with high friction under the water. It looks okay, and it stops the rope from sinking
(15-01-2018, 06:50 PM)Riscii Wrote: Hello,
You can use regular triggers and callbacks to do what you're looking for.
Create a trigger collider (as you'd normally do in Unity), then create a custom script and register to the solver.OnCollision event. You'll get a list of all particle contacts every frame, including those against triggers. Then you can do anything you like with these particles. Note that changing the gravity per-particle is not possible, but you can calculate and apply a buoyancy force to your particles that counteracts gravity.
See:
Hey! that was a quick response.
This is exactly what I was looking for, I'll check it out later today.
