Bug / Crash  No edit path Tools for obi rope
When I press the edit path on the obi rope nothing happens.
I have tested it on 2019.4.7 as well as 2021.1.6
(17-06-2021, 09:40 PM)wdoron Wrote: When I press the edit path on the obi rope nothing happens.
Simply reset your editor's layout (Layout->Revert Factory Settings). Unity will not render scene view windows if an inspector is open in debug mode. See our FAQ:
Quote:I can't see the path editor when clicking the Edit Path button in the rope inspector. Is this a bug?
The rope inspector is a sceneview window, and Unity won't draw sceneview windows if any inspector is in debug mode. Close all inspectors in debug mode (easiest, quickest way is to revert the window layout to the default) and it will become visible again.
