Pink objects and no fluid
Exclamación
I'm using ObiFluid 6.0.1 and Unity 2021.1.4f1. When I load any of the demo scenes the geometry is all pink, and there is no water when I hit play.
Going to Edit > Render Pipeline > URP > Upgrade Project Materials seems to fix the pink issue with the geometry, but the fluid source remains pink and no water appears during play.
I get the same behaviour in HDRP.
(24-04-2021, 01:54 AM)Uthon Wrote: I'm using ObiFluid 6.0.1 and Unity 2021.1.4f1. When I load any of the demo scenes the geometry is all pink, and there is no water when I hit play.
The included sample scenes are made for the built-in render pipeline.
See the manual:
Or this video:
https://youtu.be/k5Uv5ecjVM0
To setup fluid rendering for URP.
Obi Fluid is not yet compatible with HDRP as stated in our FAQ:
Let me know if I can be of further help. Kind regards,
(24-04-2021, 08:08 AM)josemendez Wrote: The included sample scenes are made for the built-in render pipeline.
See the manual:
Or this video:
The fluid is bouncing away from the sphere before it reaches it now, so it doesn't make contact and drip down. How do I change this?
Also in the Solver inspector, the Gravity and Dampening widgets are overlapping so you can't easily edit the gravity.
(24-04-2021, 11:07 AM)Uthon Wrote: The fluid is bouncing away from the sphere before it reaches it now, so it doesn't make contact and drip down. How do I change this?
Why does the fluid never reach the sphere, instead it bounces away wildly. I looked at the docs, quickly, and didn't find a reason that stood out.
Please help a newbie take his first steps with this addon. It looks very cool!
(25-04-2021, 08:54 PM)Uthon Wrote: Why does the fluid never reach the sphere, instead it bounces away wildly. I looked at the docs, quickly, and didn't find a reason that stood out.
Make sure you've installed the Burst backend dependencies as stated in the manual:
http://obi.virtualmethodstudio.com/tutor...kends.html
Burst 1.3.3 or newer
Collections 0.8.0-preview 5 or newer
Mathematics 1.0.1 or newer
Jobs 0.2.9-preview.15 or newer
Otherwise, the engine will fallback to the Oni backend, which currently has a bug with contact adhesion (fixed in upcoming 6.0.2) that affects the viscosity sample scene.
