20-04-2021, 01:50 PM
Hi Obi,
it seems that the fluid transparency in URP is not working. When you compare the built-in pipeline at the video start we can clearly see the checker pattern through the fluid. At the video end in URP the fluid is opaque. I am using the latest LTS 2020.3.4f1 with default URP packages. I also tried in new URP project but same thing. Is this a bug / overlook or I am missing something in the URP setup.
Thanks!
Thanks!
