12-03-2021, 10:57 AM
Good morning,
I am using the latest version of Obi and I am having problems to attach object to an Obi Rope. The effect that I want to obtain is that the object hangs from the rope without falling on the floor. I have read the user manual so I used an Obi Particle Attachment with target on the object that I want to link to the Rope and I used the dynamic type.
If I grab the object, the rope will follow it, and I am satisfied with this effect. But when the object is released I'd like the rope to keep the object "suspended in the air", like a true rope would do. Even if I have changed the stretching scale and stretch compliance the rope is still too stretchy and will stretch until the object falls on the floor.
I have also tried to change some parameters in the Obi Solver, such as the iterations of the distance constraint and I also changed the number of substeps in the Obi Fixed Updater in order to add particles to my rope and make it more stiff, but nothing seems to work.
What should I do to keep the length of my rope fixed and make it stiffer as it's necessary to hold the objects without stretching too much?
Thank you for your support,
Giuseppe.
Giuseppe.
