Wrap rope on Editor
Hello
Is there an easy way to manipulate rope shape on editor ? Anything that I am missing apart from adding many points to the path ?
I want to achieve something like that : https://images.app.goo.gl/1cKeZUpFnF6Y7v7g9
(01-03-2021, 11:05 AM)tpaslou Wrote: Hello
Not really...I can't think of an easier way to define a curve than using béziers. It's the way curves are defined in literally all 2D/3D software I've ever come across.
No need to add *many* control points though, a few ones should be enough as long as you use the tangent handles to approximate the shape you need.
Okay , it needed a bit of experimenting to get it done Lengua
Another question. The rope on some parts avoids ground collider. How can I fix that ? I have enabled surface collisions
Edit: Nevermind , I changed ground to box collider and it worked
(01-03-2021, 03:31 PM)tpaslou Wrote: Okay , it needed a bit of experimenting to get it done Lengua
Depends on what kind of collider you're using for the ground, and why did the rope got to the other side on the first place. Generally speaking, MeshColliders are very brittle and expensive, so best avoid them if possible.
Does this happen when moving the rope around? what kind of interaction are you using to move the rope? (dynamic/static attachments, forces, etc)
